boostin4fun
Boosted ls/vtec ohh yeah!
First thing up for sale is a set of SRP forged pistons pn#149236. These pistons have 3600 miles on them due to a sleeve cracking on my block. The set comes with three used pistons and one new one. I bought a new one because I didnt want to reuse the piston on the cracked sleeve. The used pistons appear to be in pretty good condition; there is little to no scuffing on the skirts. There is a few white spots on the sides above the first ring land on several of the pistons. I believe this is from getting hot a couple of times during the tuning process. The pistons gave me no problems whatsoever. The cylinder walls looked great when I pulled them and I had no smoking or oil consumption issues at all. These pistons yield 8.8:1 in a ls/vtec with b16 head. These are a great pistons for a factory sleeve build because they are .25mm oversized allowing you to clean the cylinders up all the way and leaving more material left on the sleeve when compared to using a full .5mm over piston. The new piston came with rings and locks so you will only need to purchase 6 new locks and rings for the remaining three. They can be purchased off of JE site for less than $100. I would have used these in my next build but I decided to go larger since my block will be sleeved. I took pictures of the front and back sides of the used ones. You be the judge of the condition of them, I have tried to be as honest as possible about it. I'm looking to get $200 shipped for them. I paid $150 for the new piston so I believe that this is a pretty fair deal. I accept paypal for payment.
