stabilysing ek ride with swap
loko123
hey i swap a b18c on ek hatch and i'm having a stability issue. when i drive it hard and hit the brakes it sways from side to side and i got to let go off the brakes to straight it out. so how can i fix that problem ?
Did you do anything to the suspension/brakes BEFORE you modified your engine? If not, there is your answer. I'd like to know how much power you are pushing and what your mods are so far.
i got some aftermarket springs and some adjustable shock but stock brakes and engines wise is a stock b18c haven't dyno it yet.
im not sure about the 91-93 but i know that the DC integra will fit on my 95 hatchback. its probably the same with your ek.
