Step By Step Turbo Kit Install?
Discussion in 'Forced Induction' started by 700HPSupra, Feb 15, 2003.
  1. 700HPSupra
    700HPSupra Junior Member
    Definitely not my first turbo kit install but my first Honda kit install. I'm installing the kit for a friend on his 93 prelude si (h23a, dohc non-vtec).
    I've installed kits on supras primarily but the kits use all existing oil feed and returns. This kit I will need to tap the oil pan and do some other neat stuff I've never done. :) My question is, are there any step by step instructions out there online, i searched by got flooded by unrelated topics. Or if anyone has done a prelude swap if they could steer me in the right direction.
    As of now the manifold, turbo, and wastegate are on the car...next step are the oil/coolant lines, 470cc injectors, regulator, pump, and intercooler.
    Plans for this car are to run it till the motor pops and at that point slop in a built h22a.
    Email me or respond if anyone as any input...
    Thanks in advance!
    Matt
  2. pissedoffsol
  3. 700HPSupra
  4. tripple sik
    tripple sik Member
    there's instructions selling on ebay for a buck emailed to you... i bought it just because it was cheap and i was curious and it turned out the instructions were very thorough... pretty much everything you would need to know to do install a basic turbo system --basic as in no standalone...
  5. DragCiVicT
    DragCiVicT Junior Member
