Stiff shifter
Discussion in 'General Tech and Maintenance' started by dman32, Jun 21, 2008.
  1. dman32
    dman32 Junior Member
    Hi
    I have a problem with my 2000 Civic DX, when I shift out of "Park" its pretty stiff, but when I do it again (from Park) its smooth? I was wondering if any one had any ideas what it can be?
    Thanks
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    have you checked your trans fluid lately?
  3. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    This might be a dumb question but do you park on a hill or slight incline?
    If so put the e-brake on first then into park.
  4. 92civicb18b1
    yep, that too, my Jeeps shifter will be stiff and kind of bang into gear any time I park it in my driveway since it's a steep incline and the ebrake doesn't work.
  5. Justin66
    Same with my moms windstar...... dumb question but hey you never know.
    Also check to make sure nothing is blocking the shifter from inside the case.
  6. nootrac22
    exeter pa
    had too look with a title like this
  7. dman32
    Thanks for all the quick replies.
    THe fliud is up but I was gonna change it anyways (100,000km). I looked at the linkages and seen nothing out of the ordinary.
  8. 93AccordEX
    93AccordEX New Member
    What about parking on a hill or incline? Do you?
  9. efhondakid
    Akron-Canton, Ohio
    And are you really 81, cause that has to make you the oldest member on here.
  10. dman32
    Its flat where I park it, and I use the "E" brake religiously.
  11. 92civicb18b1
    it may be the linkage, it's not gonna look out of the ordinary, may just need a little adjusting.
    But honestly, even my 07 is a little stiff sometimes.
  12. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    Are you really 81?
    Do you live in colder temperatures? Perhaps the fluid is cold.
    Let us know if a transmission fluid change helps any. It's recommended between 60,000-100,000 miles anyway.
  13. dman32
    I haven't bought the fluid yet, I'm gonna grab some synthenic mobile 1 or some other quality brand (have to treat my car good).
  14. BrutalB83
    Rochester Hills, MI
    So are you ever going to tell us if you're actually 81 years old?
  15. |Chaz|
    |Chaz| Well-Known Member VIP
  16. jdm-dro
    jdm-dro New Member
    orlando,florida
  17. 93AccordEX
  18. dman32
    Ok I just letting everyone know that the fluid change worked ....
    Thats for all the helpful hints.
  19. YBLEGAL
    NW Indiana
    no problem.
    lame your completely ignoring the question of age..................
  20. Aleaf.CRX
    Aleaf.CRX Hates Cunts!
    Ahaha. 81. That's grody.
