stroker kits??
Discussion in 'Civic and del Sol - EG and EK' started by Si6t3, Jun 27, 2008.
  1. Si6t3
    Si6t3 clean
    california
    Im helping my freind rebuild his b16 and hes lookin into a stroker kit. Crower makes one that puts out a 2.0 but its around 2300 bucks or somethin like that. Any suggestions? We wanna get 200+ to the wheels. It is his daily driver, he just blew the motor and plans on rebuilding it instead of a swap. What do you guys think?
  2. nootrac22
    exeter pa
    that's a lot of money for ~200whp. Like most everyone here will tell DIY turbo set up will be ~1500 and offer a lot more potential.
  3. Si6t3
    Si6t3 clean
    california
    Well the motor has to be rebuilt anyways so we figured we might as well put somethin good in there. I asked him before all this if he wanted to turbo it and he said NA is badass lol. Personally im puttin a turbo in mine once i have enough saved. But so would he be better off just puttin a swap in there or is there a cheaper way for a reliable NA 200whp setup?
  4. 99sidude
    Ohio
    I'd look into a mildly built up h22 swap
  5. JDMB20Coupe
    JDMB20Coupe Powerd With 1 Cam
    Chester, VA
    he should go on inlinefour.com they have much cheaper stroker kits
  6. PhyRe
    PhyRe Senior Member
    ct
    with higher comp better flow you could come close. or ls/crvtec it. an ls with killer cams head work b16 internals thin hg and a few other things can get you in to the 170-180whp range so with the b16 head you might get there for 2300+what ever you get for the block
  7. jdm-dro
    jdm-dro New Member
    orlando,florida
    +1
