Sunroof
Discussion in 'Civic and CRX - EF' started by Hondaman3421, Jun 11, 2009.
  1. Hondaman3421
    Hondaman3421 New Member
    The motor in my sunroof went bad does anyone know how hard it is to change or how to change it
  2. dacheat
    dacheat ..is grounded.
    strongbadia
    it's toast, you should sell me your CRX. :D
    jk, it's not too hard to pull, what exactly went bad - the whole shebang or just one of the actuators that makes it open or close?
  3. Hondaman3421
    ummm not sure when i hit the switch it sounds like its trying to open but nothing happens
  4. dacheat
    strongbadia
    there are two actuators; one that opens the roof and one that closes it. so there you go. the motor's fine, the actuator's crap, and if i recall due to the amount of plastic involved, those are pretty much not fixable (at least in any permanent way). best bet might be to buy a replacement assembly off of someone parting out their car.
    :shrug:
  5. D16SiHatch
    D16SiHatch New Member
    if you help it along will it move? and is it slow moving im both directions? if so then its most likely the motor that went bad. and there is only one of those. unfortunately its kind of a pain in the dick and you have to drop the headliner in order to replace it.
  6. dacheat
    strongbadia
    sounds like the motor is working. the actuator isn't moving the panel. but whatever.
    that part's for sure, and the only way you'll actually see wtf is going on.
  7. TurboRex90
    TurboRex90 Golden EG
    Maryland
    or if you cant find used parts or want new OEM.
    hondaautomotiveparts.com
    They sell OEM honda parts at 30% cheaper, they have saved me tons on replacement parts.
    Or you can just sell Dacheat your crx. lol
  8. dacheat
    strongbadia
    that's the best plan for all involved, really. :D
  9. Hondaman3421
    ok it doesnt move at all before it stopped working entirely i had to help it
  10. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    Good luck at a recycler but its the cheapiest. I would go with the new OEM stuff
    I get my stuff from hondapartscheap.com but the other one given will work well too
