swap b-series civic 91
Discussion in 'HYBRID -> ED-EF / DA' started by fallout, Jul 30, 2008.
  1. fallout
    fallout New Member
    what part are needed other than engine tranny and axle to swap a b18a into a ef hatch 91 cx or dx
    do you need supports or can use the one of the integra ?
    has a 90-91 integra donor car
  2. Justin91civic
    Justin91civic New Member
    Nashville, Tn
    There has been many people on this website that have done that swap before check out one of there threads or use the search function above and you will get all of the info that you need.
  3. INJEN78
    INJEN78 HS LEGEND
    OHIO
    ^correct use the search button...this is the most common swap..
    basics.mounts,shiftlinkage,motor,tranny,ecu,if your running obd1 then a jumper harness,
    is your car dpfi or mpfi?
  4. LightWeightChamp
    LightWeightChamp Honda FTW!
    MN
    you need swap mounts. i have them for sale. hasports, they are the top of the line swap mounts. ill sell em for cheap pm me.
  5. BrokenRex
    BrokenRex New Member
    if your ef is MPFI then all you'll need are a set of motor mounts and shiftlinkage. if it's DPFI then you'll need the conversion to MPFI as well.
    Parts you'll need from your teg : engine along with all sensors and distributor, trans, ecu, intermediate shaft, axles, knuckles (if your ef was a 4speed, if it was a 5speed you can keep your civic knuckles.) if your radiator is in good shape, you'd be better off taking that as well, as it will have the correct size inlet/outlet for the B's hoses.
  6. fallout
    fallout New Member
    can axle and midshaft from an auto tranny fit on a manual one cause the tranny in the teg is auto
  7. Justin91civic
    Nashville, Tn
    If you want to keep the auto tranny then yes you can keep that shaft but if you are wanting a manuall then get the shaft that comes with that tranny.
  8. INJEN78
    INJEN78 HS LEGEND
    OHIO
  9. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    The teg radiators are taller than the ef radiators. It's not gonna fit... The size difference in the inlets and outlets between d series and b series aren't so much of a difference that a leak should be a cause of concern.
    axles yes, midshaft no...
  10. BrokenRex
    it's taller yes, but it only takes a small dent or some minor cutting to make it work. and it's probably not going to leak as he says, but anytime you pinch a hose down before an inlet the possibility of bulging increases. you can get by with the radiator in your ef, but if it's hot there and you drive like the rest of us, you'll want to upgrade the cooling system eventually. why not do it now that you have the engine bay clear and a free radiator?
  11. B16RacerN2NR
    Moving back West...
    The ef already needs the lower shock tower bang'd in to clear the alternator pulley, the front motor mount bracket on the crossmember cut off to help clear with downpipe issues, and the rear crossmember needs to be notched slightly for the rear mount bracket... Now do you really think the car deserves more denting and cutting away if it's not a nessecity lol... Plus, tons of people aren't having 'bulging' problems and/or having cooling issues with the stock radiator.
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    run the integra radiator and hoses,
    cut the top one to fit(about an inch off of where it meets the waterneck on the motor,and about an inch off of where it meets the bottom of the radiator,,then you will have to put 2 dents in the hood shell(it is not visible from the outside
