Swap questions - Theory
Discussion in 'HYBRID -> EG-EK / DC' started by wiscronic, Mar 12, 2011.
  1. wiscronic
    wiscronic New Member
    Hey everyone
    I am continuing to learn about honda and engine swaping,
    I am having fun but need some clarification about some fundamentals that are fuzzy to me.
    I have a 1993 cx, stock d15b8, manual
    I have a 2000 dx, stock d16y7, manual
    I would like to transfer the d16y7 into the cx.
    Why can't I use the 2000dx ecu.
    Or can I if I replace all wires from ecu back using the wiring harness from the 2000dx. What am I missing here?
    I understand that I could use my obd1 dizzy and injectors on the d16y7 and get a d16 p06 ecu.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    You could run all the wires and splice in OBD2 components to make it all work- but running with the OBD1 ECU and distributor is MUCH easier.
  3. wiscronic
    Thanks,
    someone suggested I get a P06 obd1 ecu
    I think I have a P05 obd1 ecu now will that work with the larger d16 engine
    Can anyone explain ecu fundamentals, I know the each engine comes with its own ecu.
  4. phunky.buddha
    I don't know all the ECU codes off the top of my head, but whatever came with the DX/LX (D15B7 engine) will work close enough for the D16Y7. None of the 5th gen Civics came with a 1.6L non-VTEC, so you'll just have to use the ECU for the 1.5L.
  5. hondafreak513
    hondafreak513 New Member
    O hi O
    Correction Cal they did have a 1.6 non vtec in a few years... They made a p05 and p06 the p06 has a higher rev limiter and a slightly different fuel/air curve...
  6. wiscronic
    I originally had a bad b8 head and was just going to swap engines with the DX I also own.
    Thanks for your input, I obvoiusly have no interest in H.P. soo...
    I have just come across a cheap B7 head.
    I am currentley researching what I would have to do to make that work. From what I have read so far it looks pretty good
    I plan to part out the 2000dx.
    Thanks again Hondafreak & Calesta, it seems some of the responses to posting can be a little ruff, I appreciate ya
  7. phunky.buddha
    In the OBD1 USDM Civics? 92-95? Which one?
  8. Jswike
    Jswike New Member
    Just use your engine harness and accessories. Swap Ecu. Run vtec. Go faster.
  9. Jswike
    Jswike New Member
    Your cx harness that is...
  10. wiscronic
    Jswike, I don't have the p06 ecu if i run across one I will get it, you think everything will bolt up good, I am hoping so, going to try to get this done soon.
    Calesta :In the OBD1 USDM Civics? 92-95? Which one?
    I was told the head was off of a d15b7, i am thinking that makes it a dx, i also have the dizzy that went with that head it has 2 elec. connectors coming off of it, I don't know anything else, why?
  11. hondafreak513
    O hi O
    Im pretty sure it was in the usdm civics 92-95...
  12. wiscronic
    D15B7 1992–1995 Honda Civic DX/LX 9.2:1 102 hp (76.1 kW; 103.4 PS) @5900 98 ft·lb (132.9 N·m) @5000 16-valve SOHC
    D15B8 1992–1995 Honda Civic CX 9.1:1
    83 ft·lb (112.5 N·m) @3000 8-valve SOHC
    Found this on Wiki so who know if its true
  13. Jswike
    Jswike New Member
    Yup research it. Make sure it's a real zc. Consider it a 1.6 ls motor.
  14. phunky.buddha
    Nope.
  15. hondafreak513
    O hi O
    Really I could of sworn the p05 was for the 1.5 and the p06 was for a 1.6....
  16. phunky.buddha
    Again, don't know the ECU designations- but there wasn't a 1.6L D series block non-VTEC block in the MY92-MT95 USDM Civics.
  17. hondafreak513
    O hi O
    Ok good to know then, maybe I need to do some researching to refresh mah brain...
