Swap shops in Oregon
Discussion in 'Pacific' started by moosebrew, Jan 30, 2010.
  1. moosebrew
    moosebrew New Member
    Hey guys, any recommendations for a shop in the Corvallis, Salem area? I would even trailer it to the Portland area for the right shop. I have a 90 civic hatch with a d16zc swap. I have the surging idle issue and don't have the time to deal with it now. I am hoping a shop can fix it fast for a decent price.
    Any recommendations would be greatly appreciated.
    Thanks
    Mark
  2. REV2TEN
    REV2TEN New Member
    I know a few good shops in the Portland area, but this sounds like an easy fix. If you swaped the engine yourself, you would know a lot more about the wiring than any shop. Is the TPS pluged in?
  3. moosebrew
    Yeah it's plugged in. I ended up taking to a good mechanic in Corvallis who cleaned the throttle body and adjusted the air intake somehow and the surging went away. It's leaking coolant out the back from somewhere I havne't been able to isolate yet but it seems to be coming from around the oil filter.
    Mark
  4. REV2TEN
    REV2TEN New Member
    Possibly a oil cooler coolant hose, or a heater hose. There are a few of them back there.
  5. efhatch9086
    efhatch9086 New Member
    I do lots of swaps but I'm in hillsboro I just did this swap on my own car and had issue it was because I for got a hose its on the iacv sensor on back of intake mani it also flows coolant and deals with ur idle. also ur have that issues if sensor is damaged its a black sensor its good sized and its on back of intake mani closer to the tb
    If u need more help u can email me at jeff.paulsen1@vzw.blackberry.net
  6. 1991AccordDxH22A
    1991AccordDxH22A New Member
    The only shop i know is in aloha i believe its called speedconcept. also a very good shop in vancouver called 360 imports. can try 1 of those im going to go with 360 for my h22 swap
