Swap Trouble
Discussion in 'HYBRID -> EG-EK / DC' started by crx-si, Jan 29, 2003.
  1. crx-si
    crx-si Member
    Got the motor running tonight but it idles at 2 grand any suggestions what it
    could be.
  2. shinjin
    shinjin Junior Member
    Dose it idle down after a little ...If so check your tps..And all conections..
  3. crx-si
    crx-si Member
    I think it may be the IACV any ideas
  4. crx-si
    crx-si Member
    Its surging at idle now from 1000 to about 1600 Replaced the iacv with a good one same problem but if i unplug it it idles fine at about 850
    any ideas
  5. slammedb18acivic
    slammedb18acivic Senior Member
    pa
    it idles at 2 grand, or revs up and down? if it just revs to high i would adjust the screw on your throttle body . let the car warm up, bleed the coolant. swap known good sensors . try tps , and iacv first. make sure you have the right plug in the iacv . that happened to me when i did the swap, wrong plug. good luck
  6. kaoskustoms
    kaoskustoms Senior Member
    casper wyoming man
    :ph34r:
    there is a big ass flat head screw in the throttle bottle it self u have to take it apart and screw it till it is tight then that should fix your problem
    chad
  7. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    Check for vacuum leaks.
