91si
Well how do I test the ower to the MAP sensor because I remember it is suppose to be a certain amount of voltage. With a voltmeter what should I be testing for and how should I test it?
ALSO IF ANYONE HAS A B16 HEAD FOR SALE I WILL BUY IT FOR MY NEXT BUILD.
Get a volt meter and see if you can get a readin from the wires that go to the sensor. Im not sure how much amp its supposed to get but just check to see if its even working.
If it is, i would replace the sensor.
How about some pic of how you have it set up.
