I just got my engine and i noticed that on the shift linkage is diff. THere are like to bars, one that shifts gears and one that i guess just holds it there, but on the b16 they're on the oppisite side. How would install them? can I just cross them,and what year and model linkage can I use. Also how do you remove the pins from the harness,is there like a specail tool?if so where can i get it and what is it called? On the shock tower of my stock harness there are three wires that are not being used when i plug in the new harness from the b16,can i use those for the vtec sol.vtec oil and the knock sensor? if so how can I repin them?
can i use my stock radiator, and hoses? What timing belt will fit?
These are some of the problems that I ran into. I hope that somebody that's done this swap can help me out
thanks in advance
thanks in advance
