Swapping b17a1 into 98 civic ex
Avengerturbo1
hey guys im new here, I have searched and need some straight answers
I have a 98 civic ex 5spd.
Engine and tranny I pulled last night
I have a built bottom and top end b17a1 from a 93 integra gsr, its obv obd1
This is my first swap
Im looking for a complete list of parts im going to need and not need to do this
I need to know exactly what motor mount brackets i need, what axles, what computer what everything and compatibility so I dont screw this up.. Any help is greatly appreciated as I look to get this project started within a month, Id like to get all the neccessary parts by then
Or if theres any detailed how to's anywhere Id appreciate that, thanks guys!
rear t bracket,tranny, and drivverside mounts/brackets from si
and just extend your ecu harneess and your good
dont forget you will need to convert to obd1 with a jumper harness, use 99-00 si axles and use the ecu that comes with the motor
ok so all i need is -
rear t bracket from si??
tranny- already got one from a ls vtec integra
obd1 jumper-- where can i get it
So my engine harness from the d16y8 will match up, just needs to be extended
What year and model distributors swap out since My block doesnt have a distributor
Same thing with alternator
And radiator should be fine correct??
Power steering???
Ac im not worried about
Fuel injectors from my d16y8 will be fine???
Ecu??- what year and model can i use from?? thanks
