t3 turbo, hp per psi????
Discussion in 'Forced Induction' started by 99cvc, Nov 27, 2005.
  1. 99cvc
    99cvc Junior Member
    i'm planning to turbo my b18b and i'm deciding between the t3 and the t3/t4 turbo. how much more power difference will the t3/t4 make over the t3?
  2. jamesA
    It depends on the trim between the two different turbos, and what kind of CFMs they push. Without knowing that there's no way to give you good estimates/answers.
  3. B16CRX
    B16CRX Senior Member
    Greenville, SC
  4. 99cvc
    99cvc Junior Member
    t3/t04e turbo
    .57 COMPRESSOR WHEEL TRIM
    .60 A/R COMPRESSOR
    .63 A/R TURBINE
    57 TRIM
    t3 turbo
    compressor trim is .42 and the turbine .48A/R
    how about between those two turbos
  5. 92civicb18b1
    92civicb18b1 The Trisexual
    On my first turbo setup, IIRC I made a little under 200 hp with the 42/48 at 8 psi on my 94 b18b1.
    With the 60/48, I had ~240 IIRC, but they were completely different setups.
  6. pissedoffsol
    IMO, a 42/48 is a waste on a b-series... i wouldn't even consider it.
    63/60 is key, or 60/57 if you want to go one step lower...
  7. 92civicb18b1
    :withstupid:
    I was ona budgeted setup. The 60/48 wasn't too bad though. Spooled real quick.
  8. [Freemantle]
    [Freemantle] Senior Member
    Vero Beach, FL
    Every time I see your title I think it says "tities suck".
  9. B16CRX
    Greenville, SC
    If you want a mild setup, a .48/.60 will be good for you. Full spool up at 3400 rpm or less on a B16. Butt dyno and race experience tells me I made almost 250whp at 10 psi.
  10. 92civicb18b1
    you mean 60/48 or 42/63.
    But either way, I liked my 60/48 on the LS, I had full spool before 3400, more like 2400.
  11. hotrex
    hotrex Senior Member
    i would never runa .48 a/r hot side on a b series ever.....
    too small
  12. 92civicb18b1
    thats great....
    I was very satisfied with it and the quick spool and with a little more tuning I would have reached my goal of 250 hp.
    Oh wait, as a matter of fact, I did. I made 253 hp.
  13. 99cvc
    99cvc Junior Member
    Will i be able to make 250hp with a t3 .48 a/r hot side with stock internals? because i'm only looking for about 250-300hp for now.
  14. phyregod
    phyregod !!YTINASNI
    Central Texas
    Only 300hp. [​IMG]
  15. 92civicb18b1
    lol.
    I'd go with the .63 hot side, I suppose you could probably make around 300 with the .48, but I know if that was my goal I would opt for a 60/63.
  16. B16CRX
    Greenville, SC
    if you want to get 300 with the .48 you better have a big intercooler.
