tach goin crazy
Discussion in 'General Tech and Maintenance' started by mr.paower, Jun 29, 2003.
  1. mr.paower
    mr.paower Member
    ok my tach jumps around like crazy when I drive it hard...so I changed my spark plugs and it still does that...
    another thing when my tach jumps I can feel my car laggin a bit ...could it be my clutch slippin???? or worn out????
    also i have a new distributor on it so i dont think it could be that...
    my motor is b16 btw..
  2. tedwright
    tedwright Senior Member
    UPSTATE NY
    same thing happened in my friends car, and it turned out to be a grounding problem.
  3. B16
    B16 Super Moderator VIP
    yay area, CA
    or your alt. your tach starts acting crazy when your batt. is drained
  4. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    yup, mine was jumping around like a fucking pedalim and then my alternator went on teh high way and then battery.
    highway+noon+south florida 98degrees= nightmare
    Milan
  5. mr.paower
    mr.paower Member
    well I dont know bout the alternator thing cause i just put new alternator and new battery in...I mean the tach jumps from 4000 rpm all the way up to 7000 rpm then i ease off the pedal and its normal again...when i drive it like a grandma and just slowly accelerate its ok, its only when i try to accelerate fast. so do u guys think it could be my clutch...
  6. D See 2
    D See 2 Senior Member
    Baltimore, MD
    also, it could be your igniter... that is where your tach gets its signal from...
  7. hybrid89
    hybrid89 thistownsucks...
    SoCal
    Check the 4 wires inside your distributor cap that clip to the ignitor. These commonly come loose screwing with your rpm/timing signal. I almost gaurantee that is where it is at.
  8. 93Fury
    93Fury Member
    Ft. Lauderdale, FL
    Sounds alot like a clutch problem to me. It may not even need to be replaced, sometimes they get oils on them. Happened to me on my 92 hatch way back when. Its only when you slam on it hard correct? What about when its cold, is it any better?
  9. mr.paower
    mr.paower Member
    yea it sounds like the clutch cause when the rpm jumps the engine does sound to rev up too so i think its the clutch....
  10. sportlinecrx
    sportlinecrx Banned
    :werd:
  11. f4ff34gg43g
    f4ff34gg43g New Member
    I was working on a car the other day that did that same thing ... it jumps right when vtec kicks in right around 4 grand I tryed new spark plug wires and it stoped. try that
    steve
  12. h82w8
    h82w8 Senior Member
    orlando,florida
    :werd: I-4 floridas biggest parking lot!
  13. crxfreak
    crxfreak Member
    the same thing happend in my b18a rex....id hit the gas a bit cruisin down the high way and BAM shovels shit in my face tach jumps up and down then the car like shuts off like it gets no spark and then kicks back up the rpms to normal and its running again....one time it jumpes a few and just shut off i got in a parking lot poped my hood pulled out a plug wire it had spark...then my car wouldnt even crank it would just click then it started....now it doesnt do it anymore so i dont know....oh also when im hot roddin at about 6000-6200 the tach just shoots to 7000 or 8000 and jumps like hes sayin...and the igniter does go out on these hondas and acuras all the time so could that be it???
