Tanabe SS - Del Sol
Discussion in 'Wheels / Suspension / Tires / Brakes' started by HatchSpeeD, Apr 24, 2007.
  1. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    Has anyone had any experience with Tanabe Sustec-SS dampners on a del sol? I've rode in two different GSR's with tanabe dampners & their by far the best suspension I've encountered on the street. Problem is, there is no application for del sol's. The part number is the same for Integras & Civics but I wanted to make sure there is no difference of the del sol suspension. As far as I know, there is no difference between the del sol/civic/integra suspension that would prohibit a dampner install.
  2. TurboMirage
    no difference.
  3. E_SolSi
    ive got the ITR sustec pro SS on my sol (requires ITR LCAs)
    they fit great
    they ride beautifully
    and they handle track use very well
    no complaints from me
  4. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    What made ya go ITR dampners or ITR LCA's?
  5. E_SolSi
    5 lug conversion
  6. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    I figured that but was curious because I've seen other people with gsr's switch out ITR UCA's & such and never really thought there was a big benefit.
    Hey E, are the del sol vtec's susceptible to rear subframe tear out if running a big sway bar? I've got a pretty stiff sway bar in the rear & am scared of that happening. Somethings telling me that only happens to civics that don't come from the factory with swaybars.
  7. E_SolSi
    i suppose it would depend how big of a sway bar
    but im going to say generally no they dont have as much of a risk
    what are you running for a rear sway?
  8. B16
    B16 Super Moderator VIP
    yay area, CA
    On my del sol vtec i've been running a JDM ITR rear sway bar 23mm? I'm using the Beaks kit to prevent subframe tear, so far so good with 100+ track days on the car. :)
  9. GSRCRXsi
    MD
    mike you need to get the ASR 32mm kit :)
  10. HatchSpeeD
    HatchSpeeD ...Hi...
    Beantown
    I need to get the ASR subframe brace. Who's Mike?
  11. TurboMirage
    can i have a pic of said brace?
