Think it will work?
Discussion in 'Civic and del Sol - EG and EK' started by porkfried83, Nov 14, 2012.
  1. porkfried83
    porkfried83 New Member
    ME
    I have a p28 ecu for my d16z6. And I have a chip but not for a p28. Its a p30 chip, witch is for a DOHC VTEC. A B16 I believe. Do you think it would hurt to put it in?
    VTEC: 5400 RPM
    REDLINE: 8800 RPM
    KNOCK SENSOR: DISABLED (Don't have one)
    SPEED LIMITER: DISABLED
    I don't even rev it past 6000 rpms. Don't dear with stock internals. :confused:
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    It will run that engine fine, vtec crossover may be a little off, but ...who cares.
  3. porkfried83
    ME
    Cool, I'm gonna give it a shot!
  4. Briansol
    biggest thing is the rev limiter.... don't go much past 7200 or the D will go boom.
    other than that, you'll probably have poorer fuel economy by a few mpg's
  5. porkfried83
    ME
    ya any more then that and i'll probably throw a rod or something.
  6. porkfried83
    ME
    I'm finaly getting around to putting the chip in. One question, do I have to run 91 octane cause thats all we got around here. Or can I run regular unleaded or will detonation be a problem? Gas price's suck. But thats one thing good about the 1.6 sohc, good on gas.
  7. Dual-500
    Dual-500 Well-Known Member VIP
    Fort Worth, Texas
    I always run 91 octane and have since day 1, even with the stock D16A6.
  8. phunky.buddha
    Dallas / Fort Worth, TX
    Depends on the program in the chip...
  9. Magana559
    Magana559 The Warden
    fresno Ca
    chips good to eat not good for your engine management
  10. porkfried83
    ME
    Maybe I'll get the Demon or Hondata someday.
  11. |Chaz|
    |Chaz| Well-Known Member VIP
    Why would you even use the chip? It doesn't do anything beneficial.
  12. Jared759
    Jared759 Well-Known Member VIP
    SC
    A chip is beneficial it provides a basemap the same way hondata would when you order it from a dealer. You just don't have the "on the fly" tuning capabilities as hondata.
  13. Dual-500
    Fort Worth, Texas
    ^ If you really don't know, it's best not to offer advice.
  14. BrutalB83
    Rochester Hills, MI
    Yeah, but the chip he has isn't even for his engine. I'd say just skip it. He'll probably just end up with wonky a/f ratios and slightly shittier mpg...
  15. porkfried83
    ME
    Got a Ostrich+Extreme Hulog and chrome on the way...and I pulled the jumper and the ecu is back to stock. Just had the chip l
  16. porkfried83
    ME
    Just had the chip lying around...Can't you reprogram them eproms? And the car ran fine with the chip. Just wanted to see what it did, new to this tuning stuff. Like BrutalB83 said just skip it. Thanks 4 the info.
  17. Dual-500
    Fort Worth, Texas
    Typically an EPROM is a one shot deal to program. It takes and EEROM to be able to re-program.
    EPROM - Electronically Programmable Read Only Memory
    EEPROM - Electronically Eraseable Programmable Read Only Memory
    Could be some other stuff out there now, I did my Digital Electronics training in the early 70's and again in the late 80's.
  18. phunky.buddha
    EEPROM. If it was an EEROM, the EE part wouldn't matter at all.
  19. Dual-500
    Fort Worth, Texas
    Yeah well, it's been a while.... :)
  20. phunky.buddha
