this is weird please help me out
Discussion in 'HYBRID -> ED-EF / DA' started by BrydogSIR, Aug 29, 2007.
  1. BrydogSIR
    BrydogSIR JDM EF8
    Oregon
    I went out to my car one morning and it wouldnt turn over so i pulled the starter and noticed a gouge on it by the shaft that comes out to the flywheel and my pressure plate had a chunk off it too right where the starter was ive been racing at the strip and launching at 5500 rpm on the street with the crew, does anyone have any idea why some the bolts on my pressure plate are broken in half and some are bent and a chunk taken off the bell housing in the tranny< I have a b16 y1 cable tranny with a kaaz lsd an act 8.8 lb flywheel and exedy stage 2 clutch. Do you think launching the kaaz with my clutch and lightweight flywheel tweaked the bolts? Do i need stronger bolts(arp)? or should i take it to the shop? Ive never in my life heard of this so if you have please help
    P.S. I did hit a curb kinda hard about two months ago, Would it affect it now
  2. zccivic200hp
    zccivic200hp New Member
    quebec
    are those the original bolts ! maby it was not bolted down tight ennuf went you changed the clutch you chold check to make shre that all the bolts are tight !
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    always use Loctite on the flywheel and clutch bolts so that won't back out
  4. phyregod
    phyregod !!YTINASNI
    Central Texas
    And torque to spec. Don't over-tighten them or they'll shear.
    Sad thing is, after breaking / bending the bolts like that you may need a new flywheel and crankshaft.
  5. BrydogSIR
    BrydogSIR JDM EF8
    Oregon
    we did loc tite the bolts and wer torqued down, Im convinced that lightweight flywheel and clutch combo could'nt handle the kaaz. But anymore ideas please let me know
  6. jlicrx
    Colorado Springs
    i doubt that is it - we have a lightweight flywheel, with a welded diff, running 9.5" drag slicks and launching it at 8000 rpm and have no problems like that - we use an ACT Extreme pressure plate and ACT street performance disc
  7. 1988hondacrxsiR1
    1988hondacrxsiR1 Banned
    Midwest
    MAKE SURE TO TAP threads to remove debris and use loctite for a permanant seal
    and torque in 2 sequence 1st is 17ft lb last is 19ft lbs GOOD LUCK!;)
  8. zccivic200hp
    quebec
    im sorry but with all respect if i had your set up it wood brake the tranny and axel's before the flyweel !
  9. 1988hondacrxsiR1
    Midwest
    THAt's my setup on my b16 crx and car is doing good. no problem. GOOD LUCK!;)
