toda cams
Discussion in 'Engine Building' started by dean_mcl, Jul 10, 2007.
  1. dean_mcl
    dean_mcl New Member
    I need professional help. i just ordered toda spec c cams from nengun.com and being that the description of the cams are so discreet i am not sure if the cams i ordered are toda spec c. i emailed them and asked them but all they had to say was just to check with a proffessional tuner. well here are the specs on the cams that were available.
    Intake.
    1411-B16-00A
    Honda - B16A/B B18C - Valve Lift 220 (6.0) / 290 (11.6) / 240 (9.0) IN
    14111-B16-00B
    Honda - B16A/B B18C - Valve Lift 250 (11.0) / 295 (12.0) / 250 (11.0) IN
    14111-B16-00C
    Honda - B16A/B B18C - Valve lift 250 (11.0) / 295 (12.5) / 250 (11.0) IN
    Exaust.
    14121-B16-00A
    Honda - B16A/B B18C - Valve Lift 220 (5.5) / 280 (11.2) / 240 (8.5) EX
    14121-B16-00B
    Honda - B16A/B B18C - Valve Lift 250 (11.0) / 285 (12.0) / 250 (11.0) EX
    14121-B16-00C
    Honda - B16A/B B18C - 250 (11.0) / 295 (12.5) / 250 (11.0) 250 (11.0) / 295 (12.5) / 250 (11.0) EX
    naturally i choose b16-00C for intake and exaust assuming they are toda spec c cams..
    What has me confused is that i have been comparing lift and duration from different sources and they all seem be different. if some one can just tell me which one of these cams are toda spec c cams i will apreciate it.
    Also i am looking for a 68 or 70 mm throttle body (bbk or skunk 2)
    you can send me eamils at dean_mcl@yahoo.com
