tranny gears ?
Discussion in 'General Tech and Maintenance' started by AHHVTEC, Jan 15, 2008.
  1. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    2 part question, first, when reading gear ratios does the higher the number =shorter gears ? on sohc d series trannys
  2. newb
    newb phresh VIP
    Backwoods Northwest
    With every gear ive worked with the numericaly higher the number the lower the ratio. the number describes the number of rotations on the input side per 1 revolution on the output side.
  3. BrutalB83
    Rochester Hills, MI
    Yes, that is correct. Check out some of the transmission specs in this thread: http://hondaswap.com/reference-materials/honda-transmission-specs-29132/
    If you compare say, a B16 tranny to a B18B tranny, the ratios on the B16 tranny stay consistently higher and closer together than the ratios on the LS gearbox.
    It's the same with final drives. The higher the ratio, the more aggressive the FD is. For example, the LS FD = 4.266 while the JDM ITR FD = 4.785.
