ok i currently have a b18c1 engine with a ys1 LS transmission in my crx. my current clutch flywheel setup is a mystery. i just bought a b16 cable trans to put on the car. with it im getting a clutchmasters HD pressure plate.
my first question is on the clutch disc. the person who sold me the tranny told me that it is a 90-91 tranny. so i will need to get a 90-91 disc correct? he said that 90-91 and 92+ differ in the number of splines on the input shaft. is this correct? also what clutch disc would you recommend. i dont want it to be too aggressive but i want a nice bite to it. how much should i expect to spend on a disc? new? used?
next question is on the pressure plate. the previous owner said that it bolted to the flywheel with 9 bolts. while skimming through the helms and seeing what its gonna take to install all this it says that the pressure plate is held with only 6 bolts. the helms is for a 94 integra. do the 94+ integras only use 6 bolts? secondly, does with matter? if my current setup only uses 6 bolts will i be able to use this pressure plate with only 6 bolts out of the 9? does the flywheel only have 6 bolt holes in the 94+ flywheels?
pics of what im talking about.
from helms....
from a b16....
http://bulletproofb16.no-ip.com/pp.gif
from helms....
from a b16....
