jamesA Thank you for your business. VIP Dec 31, 2004 #1 I was reading around on HT and got to thinking... if I get a jdm itr 5 speed, would an ACT clutch meant for the S4C bolt onto it? If not would a clutch built for the c5 S80 fit onto it?
B brian11to1 Senior Member Dec 31, 2004 #3 Basically James any hydro clutch meant for the ITR should work. As long as the flywheel is for a Hydro Trans you'll be ok.
jamesA Thank you for your business. VIP Dec 31, 2004 #4 a'ight. thanks guys. just wanted to make sure before i spend 500 on a clutch and it for some reason not fit.
