trans question
Discussion in 'Civic and CRX - EF' started by crxhfz6, Oct 24, 2009.
  1. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    im in the process of switching transmissions in my 89 crx. I have an hf trans that is going in and we noticed that the input shaft had a little wiggle to it that we thought we would need to fix. i went ahead and took out the one in the car in it had the same deal. so is this actually normal or do both have the same problem?
  2. D16SiHatch
    D16SiHatch New Member
  3. mikey bottles
    mikey bottles Prof. Bottles
    S. Jersey
    not trying to thread jack, but do you know where you can buy just the input shaft bearing instead of in a whole kit? ive looked everywhere but cant find just the bearing, im sure crxhf would appreciate the info as well!
  4. jlicrx
    jlicrx Senior Member
    Colorado Springs
    we buy them from the local Honda dealer - there are 2 different bearings available, one for the small bearing case (DX/HF/etc.) and one for the large bearing case (Si/EX/ZC)
    small bearing Part No. 91002-PHR-003 - 26mm i.d. x 52mm o.d. x 15mm thk.
    large bearing Part No. 91002-PS0-003 - 26mm i.d. x 58mm o.d. x 15mm thk.
    you will want to also replace the seal:
    Part No. 91216-PL3-005
  5. crxhfz6
    crxhfz6 Member
    Manhattan, KS
    thanks. i just used one off of a disassembled hf i had lying around because it looked brand new. i got all of the seals in and it almost ready to be put back together
