Try to swap an engine in.
Discussion in 'HYBRID -> ED-EF / DA' started by KillerCRX91, Aug 25, 2009.
  1. KillerCRX91
    KillerCRX91 New Member
    Now I have an 1991 CRX DX and it has an auto tranny. I was goin to make it an manuel but it's to much work and it's never goin to be 100% good. So I looked and they have an ZC with an auto tranny, and a B16A1 with an auto tranny. So ether on of these I would LOVE to have in my car but the problem is that what AXLE'S,SHIFT LINKAGE CABLES, and ECU do I use?
  2. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    The conversion can be done well....100% Its no harder then swapping a motor/trans/axles/link/ecu into your CRX.......
    Its a big disadvantage to be AT. CRX against CRX....the manual will walk all over the AT. But a swap is fun to drive for sure.
  3. KillerCRX91
    I bean looking at this alout and the hole metal and gap this scares me
    Automatic to Manual crx conversion
    and to put on top of that I need a shop to do it because I don't have the right tools.
  4. CAFROG
    NOR-CAL
    Look into other articles on the conversion. The pedal change over is a little bit of a pain but the trans, shift linkage, axles, ecu
    is all there when you purchase the 'swap' You can still do the AT swap but I don't see it being that beneficial for driving or even re-sale.
  5. hondacivicdx92
    hondacivicdx92 Hamby
    Indiana
  6. SwapShopRacing
    SwapShopRacing Member
    650n Barranca ave #a Covina, Ca 91723 (626) 261-4
    Stick with the A/T to M/T swap, pretty easy on that chassis. I have seen people do the A/T swap with nothing but issues.
  7. INJEN78
    INJEN78 HS LEGEND
    OHIO
    if you go zc then you can keep your tranny and use everything..
  8. KillerCRX91
    That's what I heard and what I was thinking. The only thing they sad I needed to do is to get the EUC upgraded.
  9. KillerCRX91
    I mean ECU. But yeah I saw someone did it before. Like I don't really care if the engine isn't as fast as an manuel I this what an new engine.
  10. INJEN78
    INJEN78 HS LEGEND
    OHIO
    yea just get the ecu for the motor..
  11. KillerCRX91
    But I bean looking and looking and I can't an Auto ECU for an ZC?
  12. INJEN78
    INJEN78 HS LEGEND
    OHIO
    then run an auto ecu from something else..and have it chipped/basemapped for your setup
  13. daloco1
    daloco1 New Member
    williamsburg, va
    89 teggy auto ecu.
