trying to replacing rear brake pads was a disaster
Discussion in 'Wheels / Suspension / Tires / Brakes' started by cxnsi, Nov 19, 2005.
Thread Status:
Not open for further replies.
  1. cxnsi
    cxnsi Junior Member
    ride: accord 98ex 4dr
    me and my homeboy were trying to replace the rear brake pads with OEm quality pads i had bought online. unfortunately we did not read proper documentations before we started; the break is now air filled. the piston is loose from the caliper. We had to call a tow truck to get us to BreakCheck. They said they do not install pads from anyone else but their own. so we have to buy new pads and installation charge (~$80), bleed ($25), and a new caliper (~$175). So the estimate came out to be around $300. We had to leave the car there so they could fix it. ................man, i feel like shit right now....
    any comments on the pricing?
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    you live and you learn.
  3. MXDesa
    MXDesa Senior Member
    Queens, New York
    What did u do?? Did u try to press in the caliper with a C clamp or did you twist it in?
  4. Nuke209
    Nuke209 Member
    you can use pads, doesn't have to be EXACTLY what they say
    I believe the rear calipers, you have to twist the piston back in, and fronts used the C clamp
  5. 92civicb18b1
    92civicb18b1 The Trisexual
    I think he probably depressed the brake before he put the caliper back on/
  6. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    How is it possible not to know how to change brake pads?
  7. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    I guess they thought you change the rears the same way as changing the fronts, easy mistake to make for a novice tuner.
  8. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    the rear need a special tool to do right. The tool cost 10 bucks or takes 10 mins to make. The shop sounds like they are dicking you around, no pads but their home brand? Never heard of this before
  9. phyregod
    phyregod !!YTINASNI
    Central Texas
    [​IMG][​IMG][​IMG]
    Yeah, stay off of the brakes until you get 'em completely re-assembled.
    Oh well, now you know...
  10. reckedracing
    reckedracing TTIWWOP VIP
    NY
    haha
    brakes are like intro to auto type shit...
    you need to bury your tools and never touch your car again
    or do some more research mang...
  11. 92civicb18b1
    yea.. brakes are really simple.
    On the Audi it's literally 2 bolts and a caliper tool or C clamp, well you can say 7 bolts if you consider taking the wheel off too.
    The first car I ever worked on was a VW Rabbit with some major electrical problems no one helped me but I got it to run and drive for a while. [​IMG]
  12. jamesA
    wow. Even brian and I didn't have any problems doing mine.
    You don't NEED the special tool to get the piston back in, but it would make it 10982 times easier to do. We had to twist the piston back into the caliper with a crowbar until we could get the caliper around the rotor.
    I'm just glad I didn't fuck up, it would have been an expensive learning experience.
    I spent 90 total redoing my rear brake pads and rotors.
  13. 92civicb18b1
    I spent 65 for the front and rear pads.
    Calipers were fine. And i used a good old C clamp all around. It took some time because the A4 doesnt have a plus design in the rear. It has 2 little grooves on the sides. So it's Audi tool or no tool. I just used the C clamp tot push and twist and back off after each turn to release the pressure....It worked.
  14. phyregod
    phyregod !!YTINASNI
    Central Texas
    Once I get my brake swap complete and settled in, I'm going to replace my pads and disks.. Got to get track-worthy stuff. I'm thinking EBC green stuff pads. Not entirely decided yet. It needs to be streetable too.
  15. 92civicb18b1
    I kinda want to upgrade my brake on the A4, but it's going to be pointless with the untuneable ECU that I have. So that means no SC project, no TT project and N/A is just out of the question with the 12V. It would just be a heavy, slow car that stops fairly well.
    But A8 rotors and 993 calipers are so tempting.
  16. phunky.buddha
    Dallas / Fort Worth, TX
    The pricing from the shop isn't THAT bad really... but next time, just rebuild the caliper on your own. It's not that hard, and it's a good learning experience.
    Brake upgrades are never pointless... unless you ask E_SolSi about what I want to do- then you get comments like "You're just not right!" and crap like that.
  17. brian11to1
    brian11to1 Senior Member
    price - too much.
    you not knowing how to do brakes, just means you deserve to pay the $300 ot have it fixed. then please do us all a favor and dont attempt to do a swap.
  18. E_SolSi
    with the brake setup that you are talking about i wouldnt be suprised if the air bags deploy the first time you stand on em
  19. 92civicb18b1
    LMAO.
    I was going to use 4 piston calipers and 12" rotors.
    Or maybe even 12" rotors and 2 piston calipers to cut the cost in half.
  20. phunky.buddha
    Well, that would be a good excuse to get a new steering wheel. [​IMG]
    I was thinking something much larger than that, and in a car that's already lighter than what you have... and has 12 inch brakes already too. :)
Thread Status:
