Turbo GSR
Discussion in 'Forced Induction' started by B18bc3po, Mar 5, 2008.
  1. B18bc3po
    B18bc3po New Member
    I am debating on whether or not to boost a GSR motor or not. with the 10.0:1 compression is that too high for boost, or does that just mean i can hit higher hp with less boost? I plan on fully building the motor, just seeing what I can do to avoid making the comp even higher?
  2. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    10:1 is not really high, its prolly a good mix of on and off boost power. I just turbo'd a 11.5:1 car :)
    As long as the tuning is good it will be ok!
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    tuning is the key
  4. B18bc3po
    B18bc3po New Member
    Ok sweet, im shooting for pretty high hp and prolly run Hondata, i still gotta do alot of research on engine mngmt because im not that knowledgeable about that. but i still have a while, just looking ahead.
  5. Briansol
    are you planning to tune yourself or go to a shop?
  6. B18bc3po
    B18bc3po New Member
    lol o no, i would prolly go to a local guy around here..seandata, or go to autolab in KY. m
  7. 99sidude
    Ohio
    I've been boosting 8 psi on a stock b18c for awhile now with no problems
    knock on wood
  8. B18bc3po
    B18bc3po New Member
    Lol sweet, what kind of numbers are you putting out? if you have dynod.
  9. 99sidude
    Ohio
    no #'s yet. I'm running a jrsc basemap. I'm hoping for 250 whp
  10. 98civicproject
    98civicproject New Member
    Colorado
    i lowered the compression on my motor to 9:1.its a jdm b18c. yes running 8lbs on a stock comp ratio is safe but if you want more psi be careful.i dont know but ive always heard you cant put to much psi on on a high comp motor. i listen to my machinist over anyone else, but thats just him
  11. B18bc3po
    B18bc3po New Member
    what did you do to lower the comp? Thicker HG?
  12. Briansol
    see what THEY like to tune with. if the tuner knows the program, you'll get a better tune.
  13. a_white51
    a_white51 New Member
    Elma, WA
    a thicker head gasket wouldn't drop compression that much, he probably swapped pistons
  14. 98civicproject
    Colorado
    yea i put in 84mm je 9:1 pistons
  15. B18bc3po
    B18bc3po New Member
    yeah this will be more than likely my tuner www.seendata.com, that or ill go down to CFT with my buddy
  16. Turbo&Auto
    East Burg, PA!
    B has a good point. My buddy's shop just got a dyno but they only tune with Haltech and SAFC's. They arent willing to learn anything else either. So be aware of what THEY like to use :)
  17. DOHCtaDA9
    DOHCtaDA9 New Member
    Hamilton, Ontario
    Do they have much success with tuning with SAFC's? Thats what I plan to use on my setup.
