there is no such thing.
psi means jack shit.
psi is the measure of air pressure that is NOT making it into the chambers for cumbustion. its read in the intake manifold @ the map sensor most likely...
a motor that can comsume a butt load of air due to free flowing head, huge combustion chamber, and so forth will see much more power, and at the same time, a lower psi.
simple example:
same turbos, same motor...
car A has complete head work- ported to all hell, cc'ed combustion chambers, oversized valves, ported TB and IM, etc..
car B is a stock head
car A makes 200 whp @ 10 psi
car B makes 200 whp @ 14 psi
same turbo, same motor, different breathing properties.
