Two questions,
pageusaf
I have a 1990 CRX Dx, d15b2.... what is the OBD on my engine?
And, if I buy an engine from this company, will it be ane asy swap? It says it only fits the CRX SI so will I need to weld new motor mounts? and is that engine compatible with my cars OBD?
The mounts will work in your DX too.
If you're going to blow $405 with that company, you should just buy from Hmotorsonline. The price is cheaper, the quality is KNOWN to be good, and the engine will be fuel injected. HM sells their SOHC ZC for $390 without auction bidding.
Thanks a lot for your input guys, i wont go with that motor... 400 is a lot considering its used, its not even a complete motor, and its bonestock
