uberdata questions???
ok new at this uberdata stuff I know you buy the chip kit and install into your ecu. Now does that install into odb0 ecus too or obd1 and up?? another question how do I dl my tuning on the chip, like online or cd? And where do I go to dl it to my chip, is there a wire that run from my computer to my ecu? i have a ls motor with a turbo running 8 psi and i need fmu. I heard uberdata is the best and cheapest please help me out.
Originally posted by revolution8k@Nov 25 2004, 03:49 PM
just wait for beerbongskickass. He'll give you an 80 page tutorial.
[post=422191]Quoted post[/post]​
Well I actually wasn't going to post much really. I think this guy needs to do his own research and learn on his own. I can point him in the right directions though.
http://www.ecimulti.org/uberdata ... uberdata site
http://www.hondata.com ... lots of good tech info
http://www.pgmfi.org ... you can find everything here
To answer your questions. Uberdata is for obd1 ECU's so if you obd0 your going to have to convert to obd1. You then need to socket your ECU (parts are maybe $20) so you can install the chip. Basically you use the uberdata software to make the maps and set everything up (fuel, ignition, vtec, rev limits, etc...) and you save all this as a bin file, this is a basemap. Then you take your chip burner and burn the bin file onto your chip. Once that is done you install the chip into your socketed ECU and then you tune the car in the same manner with a wideband o2 sensor or on the dyno. Sounds easy don't it?
Originally posted by hcivic.com@Nov 25 2004, 05:35 PM
if you whant to run obdo gettodyne is still around
[post=422227]Quoted post[/post]​
Your joking right? lol...
Ghettodyne was over and done with a long time ago, TurboEDIT is far more advanced and still being updated.
If your not interested in converting to obd1 and your going to stay obd0, go with TurboEDIT... http://www.turboedit.org/
wow, gd, i forgot all about that. i loved the sponge bob on the software :D
