uhhh...whats this?
Discussion in 'Prelude' started by prelude316, Sep 4, 2008.
  1. prelude316
    prelude316 New Member
    Wichita, KS
    k i bought a JDM H22A for my 96 prelude Si. it had previously had a F22B2 sohc nonvtec in it. on my old tranny it had the thing in the picture but my new one doesn't. i don't know what it is...so any help would be appreciated.
  2. eg6sir
    fixed your pic
    whats what?
  3. efhondakid
    Akron-Canton, Ohio
    Yeah, what little thing are you talking about? VSS? Tranny cooler? Half shaft?
  4. prelude316
    Wichita, KS
    the thing with the hoses coming out of it on my tranny. my new one doesn't have the spot for those.
  5. BMan88
    BMan88 New Member
    Cali central valley
    That is your 'speed sensitive power steering' valve. It changes the amount of assist at changing speeds.
  6. efhondakid
    Akron-Canton, Ohio
    Try again, those are tranny cooler lines. Prelude316 is that pic of the old tranny or the new one?
  7. nootrac22
    exeter pa
  8. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    Ya it's a 'heater/cooler' system for the VSS. In the cold, warm coolant will help to bring the sensor's lube up to temp. In the hot, it helps keep it from overheating. Basicly same reasons why the IACV has coolant lines going to it.
  9. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    You can't tell him to try again and give the wrong answer yourself lol...
  10. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    just loop them together, done
  11. caboose
    caboose USDM to the bone
    Hamilton, MI
    Can't you just take the whole speed sensor off the old trans?
  12. prelude316
    Wichita, KS
    that pic is of the old tranny. but there are lines coming out of my firewall that those hoses connected to. so should i just loop the two lines together?
  13. AHHVTEC
    Alabama
    umm im not aware of any lines coming out of the fire wall that go to the tranny
  14. nootrac22
    exeter pa
    If I could see the pic I could help. I hate it when people use photobucket instead of just uploading the pic here.
  15. nootrac22
    exeter pa
  16. AHHVTEC
    Alabama
    if your talking about the heater core hoses those dont go to the tranny
  17. efhondakid
    Akron-Canton, Ohio
    Those two little lines are for the tranny cooler, they dont go into the firewall, they can just be looped and it will be fine.
  18. B16RacerN2NR
    Moving back West...
    OK, second time lol, they are not for the tranny cooler. They are to help with cooling the VSS ONLY, they have nothing to do with the tranny...
    1 person likes this.
  19. YBLEGAL
    NW Indiana
    Nooo they are not for the tranny cooler!
    There is no manual transmission cooler for F22/prelude transmissions. I know this from my friends personal experience.
    They are just coolant lines. I would figure out how to splice them into your current cooling system; not to hard, coolant in one side, out the other. Then you know your not going to burn it up from extended driving and such.
    On the same note, my friend just put caps on each hose barb and ran it with no issues.
  20. efhondakid
    Akron-Canton, Ohio
    I missed your first correcting post, my bad. Its not coolant that runs through those lines is it, its tranny fluid. I always thought it was a cooler.
