Urgent! Having Problems Bolting up Tranny to b18a1
Discussion in 'HYBRID -> EG-EK / DC' started by streetracer11684, Jun 5, 2005.
  1. streetracer11684
    streetracer11684 Junior Member
    Connecticut
    hello everyone this engine swap is really driving me nuts...but anyway here is my problem!! I have a 95 integra hydraulic transmission and for some reason it isn't bolting up to the b18a1....all the bolt holes line up, its just not sliding into the clutch all the way....im jus want to know if it fits wit the clutch that is bolted onto the engine or do i need to buy a 94-up clutch..
    ok thanx
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    I believe you need a clutch for the transmission, because think about it, you need the clutch to be on the splines of the tranny, which means you probably have a clutch with the wrong splines on it.
  3. 92civicb18b1
    92civicb18b1 The Trisexual
    b18a1's had less number of spline or smaller or something of the sort.
    I would defenitly get a new clutch, get one for a 94+ teg.
