urgent help!!
Discussion in 'Accord' started by philyphreak2127, Feb 6, 2008.
  1. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
    okay so I have a dumba ss question but I am doing a brake job on a 94-97 accord with the 4 banger, and the rotors have a goofy setup to me anyways. they have 4 bolts on a bracket that holds the rotor down and one huge ass nut in the middle what do I need to take off to get the rotor off?
  2. nootrac22
    exeter pa
    machine shop. has to be pressed off.
  3. philyphreak2127
    Littleton, co
    so there is literally no way for me to take off the rotor? that is dumb.
  4. nootrac22
    exeter pa
    it's supposed to come off, but dosent. I have a 93 (previous gen) and had the same problem, the chiltons shows removing the 4 bolt and taking the rotor off. However due to the heating and cooling of brakes, even with the bolts off the rotor won't come off (even with a 5lb sledge).
  5. philyphreak2127
    Littleton, co
    damn. this is for a customer car too. but I am working with limited tools. oh well I guess. but see we can't even get the 4 bolts out.
  6. nootrac22
    exeter pa
  7. philyphreak2127
    Littleton, co
    6. there are 4 6 point bolts on some sort of bracket above the rotor itself. I have looked up write ups to see any little tips I could find. none to be found. I found one write up that showed screws. for reference purposes it is a 95 accord lx sedan. automatic.
  8. BrutalB83
    Rochester Hills, MI
    Yeah, the Accords from those years are infamous for having a stupid brake design that's impossible to get off. I tried to do that myself once too, and I ended up having to take it to a machine shop.
  9. philyphreak2127
    Littleton, co
    I told her I couldn't do it. Put the car back together. Took the parts back to the place I got them from gave her money back and suggested that she take it to a professional shop and tell them that she needs new rotors. thanks for the help by the way!!
  10. newb
    newb phresh VIP
    Backwoods Northwest
    I dont know cuz Ive never worked on one, but would a big gear puller work? Grab the outer edges and push in the center? Like I said, never worked on one, but just offerin an idea.
  11. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    Is it the same as the 92? I pounded mine off with a sledge. Had new ones ready to go.
  12. philyphreak2127
    Littleton, co
    I wish I could show you guys a pic to explain better...but ya know how normally they have cotter pins in the center of the hub on what looks like a huge nut? well this time there was no pin, and it appeared to me at least that the "nut" was on top of the rotor bracket or whatever you wanna call it, the peice of metal with the bolts in it holding the rotor down.
  13. newb
    newb phresh VIP
    Backwoods Northwest
    Ooo, ok I think I understand now.
  14. philyphreak2127
    Littleton, co
    sorry for the stupid explanation I don't know the technical names of the parts.
  15. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    is the giant nut you are talking about the axle nut? if so you need to unstake it and get the sockety to fit and get a big ass breaker bar to get that sob off. once you have the caliper, etc off and the brake,hub and all that is attached off you can take out the bolts on the back side. leave two in and hit them with a big ass hammer and you will seperate the rotor and hub from the assembly.
  16. philyphreak2127
    Littleton, co
    nice. too bad its a little too late to do that to the last car but I'll keep that in mind for the next accord I work on. The other thing is I don't have a socket or wrench big enough to fit on the axle nut. I had a 1 inch wrench and that wouldn't fit.
  17. 91accordwithwork
    91accordwithwork kid that everyone loves!
    Wauwatosa WI
    yah i am going through the same thing right this moment, i have a 91 accord, with the same problem what should i do to seperate the rotor so i can put the new rotor in?
  18. sufikation
    sufikation Active Member
    Fruitland, ID
    from the sounds of things people say machine shop, this is an old post so im sure if you can get a hold of the thread starter he may have some advice on what he did to fix the problem. good luck.
  19. 91accordwithwork
    Wauwatosa WI
    k i think im going to just live with the grinding.......
    nicely done honda though : )
  20. budda
    budda New Member
    Cincinnati
    ABSOLUTELY no problem involving the brakes should just be "lived with." Trust me.
