Vroom Vroom Disease
Discussion in 'Civic and del Sol - EG and EK' started by dashinghoopdi, Dec 18, 2011.
  1. dashinghoopdi
    dashinghoopdi New Member
    I have a 1996 Honda Civic Cx with 550,000 miles on original engine. The engine is a D16Y7 (1.5). No cel, not burning oil, Manual Trans, original clutch. When car is cold car idles perfectly. When car reaches N.O.T. and cold start system is inactive the engine fluctuates from 1000 to 2500 rpm's (vroom vroom disease) by its self. I am the original owner of the car and it is completely stock. Got any suggestions?
  2. eg6sir
    vacuum leak? idle adjustment screw?
  3. eg6sir
    spring in the fitv (fast idle thermo valve) under the throttle body could be stuck .. not sure if it has one though
  4. dashinghoopdi
    Thank you. If there is am adjustment screw were would I look? Is this adjustment set at the factory? As far as a vacuum leak how should I go about locating the leak? I don't have much experience in diagnosing engine problems. I will see if I can find out if the car has the FITV.
  5. eg6sir
    adjustment screw is on the face of the TB... fitv would be bolted to the bottom of the TB... to check for vacuum leak, start the car..while its running spray carbon cleaner all around the intake side of the engine where there are gaskets, hoses etc.. if it starts to die out, u found ur leak..
  6. UNDR8D
    UNDR8D ...has a job!
    8OH!5
    Ya...sounds like a vac leak
  7. Briansol
    It could also be air in the coolant. try bleeding it (or even flushing it if you haven't done so in a while).
  8. UNDR8D
    8OH!5
    Air in the coolant causing a fluctuating idle???
  9. Briansol
    yup could be headgasket too, but he hasn't reported any brown milky oil.
  10. CHIPMONK
    CHIPMONK New Member
    vroom vroom
    No coolant issues with car. No loss of coolant. No coolant in the oil.
  11. efhondakid
    Akron-Canton, Ohio
    My bet would be the FITV or IACV.
  12. wikedeye
    wikedeye Well-Known Member
    Savannah, Ga.
    IACV x2. Start there and then check for vacuum leaks.
