VTEC head swap
Discussion in 'Accord' started by CB792, Oct 7, 2008.
  1. CB792
    CB792 cb7 92
    at home
    I have a 92 accord sohc lokking to put on a vtec head on a f22a1 block. What head can i use to make a dohc? Thanks for the help.
  2. haao13
    haao13 New Member
    PA
    none. youd have to get a sohc vtec head
  3. CB792
    CB792 cb7 92
    at home
    thanks what all parts do i need 2 do this swap?
  4. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    or get a h23 or F22b JDM head for you A1 block. H22 heads will not fit 4th gen accord blocks, neither will th F23 heads without some work.
  5. CB792
    CB792 cb7 92
    at home
    what do u mean by some work what will i have to do i was told a f23 would bolt up with no work help plz thanks
  6. zone90cb7lx
    zone90cb7lx just a noob...
    So Cal
    a sh*t load of wireing and work and cash... you could do a whole motor swap for that much, and for about the same price you can turbo what you got and have way more get up and go then another head, search around in other forums at this sight or at cb7tuner.com that f22a motor has a sh*t ton of potential. its got low compression and not having vtec doesnt mean you cant run with the big dogs, its a misconception. dont get me wrong, vtec is great... you just got a ton more options that'll leave some cash in ur pocket. please, search away....
    idk who told you this but there wrong... if you just bolt it on theres nothing to tell the vtec to activate.... i mean you could and it would work but it be pointless...
  7. CB792
    CB792 cb7 92
    at home
    all i would need is a vtec ecu and the silonoid i do belive if im wrong correct me thanks
  8. BrutalB83
    Rochester Hills, MI
    You need an entire VTEC head, not just the solenoid, and then you'll also need to run wires from the head to the ECU in order for the VTEC to function. You can run the wires yourself or buy a pre-made harness...
  9. no name
    no name New Member
    wisconsin
    so will an h22 head actually bolt on to a f22a blockk? i was wondering that myself i wanted to put an h22 head ont the f22a block in my preludebeside wiring and ecu will it bolt on?
  10. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Not without modifications to the head and or block , I dont remeber which. You can do a H23 Dohc, or a F22b JDM dohc swap.
    CB7Tuner Forums - Search Results
  11. no name
    no name New Member
    wisconsin
    o ok.. so im better off boosting the f22 huh... it has a 9 to 5 to 1 compression.
    will i need different pistons? the whole motor has been rebuildt with forged rods and forges bolts. will it handle being boosted wiht thata high of comoresssion?
  12. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Try this first....F22a6 camshaft, H23 intake manifold, S2k throttle body, F22a4 header or aftermarket header. Exhaust and Intake. If its a five speed you can try either a H22 or H23 transmission, both have tighter gears than the accord. H22 being the tightest geared of the two. A Prelude ECU or accord Ex ECU can be used to run the IAB's in the intake manifold. That should be a good start for you.
  13. Justin66
    Justin66 The Hondaswap Canadian
    Peterborough, Ontario
    Wow i cant follow that lol.
    Either turbo it, or swap a whole new engine.
  14. BrutalB83
    Rochester Hills, MI
    Is the S2000 throttle body a complete bolt-on to the H23 intake manifold?
  15. zone90cb7lx
    So Cal
    yea thats a new one on me.... the other stuff was perfect though, thats verry simular to what im goin to be doing and should have done by the end of december....
