vtec install on a d16y7
Discussion in 'Civic and del Sol - EG and EK' started by 99civicproject, Aug 30, 2009.
  1. 99civicproject
    99civicproject New Member
    cincinnati
    what all do i need for a vtec install on a d16y7
  2. efhondakid
    Akron-Canton, Ohio
    Search for "mini-me"
  3. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    A minime is a d16 head on a d15 block. The 16 head on the 15 block raises the compression. You'll need a d16y8 head from a civic ex, solenoid, a y8 ecu and run wires to the ecu for vtec.
  4. tabKola
    tabKola New Member
    Tewksbury MA
    You also need Y8 injectors and also a Y8 intake manifold, throttle body, and IACV if the car is a 5 speed.
  5. austinkli
    austinkli The Blackberry Dude
    Jacksonville, Fl
    Are you saying you currently have a d16y7 and want vtec on it or that you are putting a d16 head on your current motor?
  6. BrutalB83
    Rochester Hills, MI
    What's the difference between these two things? Either way, he's going to need a VTEC head...
  7. 97h22dxcoupe
    97h22dxcoupe senior member
    Coffeyville, ks.
    i got what you need in my garage tons of y-8 parts including head and block injectors fuel rail for y-8 head and intake mani and throttle body pm me if interested.thx bro..
