Vtec oil pump
Discussion in 'Engine Building' started by japspec01, Apr 7, 2004.
  1. japspec01
    japspec01 Junior Member
    Is it pointless to buy a complete vtec oil pump. I was thinking that I could just use the ls oil pump housing and change the oil pump gears to a vtec one. Doesn't that make sense. I guess you would need to swap the oil pump pressure spring or reg it to give more pressure.
  2. japspec01
    whats wrong, to tough of a question?
  3. hybrid89
    hybrid89 thistownsucks...
    SoCal
    the problem is finding just the gear and spring (in good condition and without the housing mind you) without having to go to the dealer and spend mucho dinero
    matt
  4. japspec01
    Well they sell aftermarket oil pump gears that are better than stock. You can also mess with the LS spring to give alittle more pressure. Is their anyone on this forum that has try to do this?
  5. pissedoffsol
    the problem is you didn't ask enough of a question.
    are you trying to put this in a non-vtec LS/crv block?
  6. japspec01
    Yes I'm putting together a LS/vtec block. I was just trying to make the question as plan as I can so no one would change the subject. I see that happens alot on forums. I think the oil pump housing is the same. I think that the different in a ls and vtec pump is the gear and spring. I'm not 100% if this is correct but if that was the case, Why spend money on buying a whole oil pump when it would be cheeper to buy the vtec oil pump gears and put it in the ls oil pump housing?
