VTEC On a switch
Discussion in 'Civic and del Sol - EG and EK' started by skellagher, Nov 24, 2008.
  1. skellagher
    skellagher Elder Driver
    Newark, De
    ok so i have been having troubles with vtec engaging oil pressure is fine i swapped the ecu and still nothing also put my solenoid on a friends car worked fine so what i wanna do now is just put vtec on a switch so how would i go about it i have a d15b7 with the z6 head everything is wired properly and there is no CEL so all i really need to know is how do i wire it up so i can use the switch for it thats on my shift knob? please help.
  2. Luis998
    Luis998 Honda Enthusiast
    Orlando, Florida
    A VTEC switch on your shift knob?:huh:
    I'm not going to even TRY to field that side of the question. First of all, what ECU are you using?
  3. skellagher
    Newark, De
  4. skellagher
    Newark, De
    i just want it wired up so when i get above 4k i can hit the button on the b&m knob i got and with the 12 volts going strait to it, it should kick on
  5. austin20110
    austin20110 New Member
    Northern Va
    how do you know the vtec isnt engaging
  6. Luis998
    Orlando, Florida
    Oh, I JUST re-re-read your post and figured out that you are asking, and correct me if I am wrong, to be able to control when your VTEC engages, correct? You could get a VTEC controller.
  7. skellagher
    Newark, De
    theres no change in the power trust me i have had a 97 ex i know what it feels and sounds like
  8. skellagher
    Newark, De
    i AM CHEAP ;) real low funds till after christmas
  9. Luis998
    Orlando, Florida
    The VTEC crossover should be seemless in a properly tuned engine from what I have learned.
  10. skellagher
    Newark, De
    i just wanna push a button whenever i need it for now until i can afford the apexi thing
  11. austin20110
    Northern Va
    ok mounting it on your shift knob probally isnt a good idea I'm going with luis on this one get a vtec controller and figure it out through that
  12. skellagher
    Newark, De
    there is a difference in sound though is what i was trying to say
  13. austin20110
    Northern Va
    well thats the technical term
  14. austin20110
    Northern Va
    but if your hell bent on ghetto rigging your car run a 12 volt switch from your solinoid, i guess, not a real common question
    but i would reccomend you save your money and do it right, before you mess something up
  15. skellagher
    Newark, De
    got ya i was just seeing if there was a cheap temp fix for it thank for your input
  16. stevennn09
    stevennn09 Member
    Ohio
    word. you shouldnt be able to hear a sohc vtec. and 97 ex's dont have a vtec anything near a b series either. just run a pos wire from the silenoid to a light. like a christmas tree one or something like that. if it lights up around 4500 i beilve is when sohc vtecs engage, than your vtec is working
  17. GlassHeadlights
    Calgary, AB
  18. stevennn09
    stevennn09 Member
    Ohio
    i think we all know what he wants. but i think he just doesnt think it's working.
  19. 94H_Ex
    94H_Ex Under employed
    Florida
    on a z6 head theres a plug for the oil chamber for VTEC, on the same side as the dizzy close the the vtec solenoid. you can pull that plug, T off your oil pressure sensor, and run a steel braided line to that port. it should improve your vtec if what i heard is correct. as your RPM goes up. it'll engage your secondary lopes.
    on other advise. maybe your ports for vtec are clogged. thous, low oil pressure to engage vtec. I know when you take the solenoids from the head, theres a gasket that has a some what filter on it. possibly it could be clogged. *On my 94 civic i had a p06 ecu and i ran a switch for my vtec*, it made no difference.
    * Ran the switch because i had a dx engine harness and the car came with a p75 ecu... such crap.
  20. skellagher
    Newark, De
    honestly all i want is just to know how to hook the switch up do i include both the oil pressure switch and solenoid or just the solenoid?
