i have a jdm vtec solenoid from a b16. im doing a ls/vtec swap. now the jdm solenoid doesnt come with the pressure switch. it just not there. how do i wire for vtec without the pressure switch?
you don't. you will need to disable the pressure switch lookup on the ecu with a chip system like uberdata or hondata to disable the ecu from looking for it.
but, the vtec solenoid isn't a part of the pressure switch. its actually below it on the head.
