vtec
Discussion in 'Civic and del Sol - EG and EK' started by stevennn09, Aug 10, 2008.
  1. stevennn09
    stevennn09 Member
    Ohio
    what should i install on my d16z6 to make vtec hit harder that's not gunna cost a sh*t load of money
  2. BrutalB83
    Rochester Hills, MI
    Nothing. The part that you're imagining is just that...something you made up in your head. There isn't any one part that will "make VTEC hit harder" (whatever the hell that means). You can adjust the VTEC engagement points via various electronic piggyback devices (a V-AFC for example), but there is no singular part that you can easily and cheaply bolt on to make your VTEC more effective...
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what do you mean by hit harder i hope not the crossover
  4. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    a new cam with really wild vtec lobes and small low end lobes.....u'll get the kick, but that's lame
    the correct way is smooth.
  5. sernmd
    sernmd New Member
    i put a chiped po6 (modified) in my sol made the vtec engage alot stronger hits at 5200 rpm and has nice pull to 7500.... costom chip in the ecu, but the single cams never "hit hard" tho regardless of what u do...
  6. stevennn09
    stevennn09 Member
    Ohio
    i dont want it to like throw me back in my seat. i just want more power than i have once i hit vtec. i was thinking a cam and some mild head work.
  7. AHHVTEC
    Alabama
    yea that with a tune will do the trick
  8. stevennn09
    stevennn09 Member
    Ohio
    u think cam, springs retainers maybe an intake mani and a header would do that? get my ecu chipped and tuned.
  9. AHHVTEC
    Alabama
  10. prpprimo
    prpprimo Hondaholic
    ABQ
    maybe an amp and some subs :D
  11. stevennn09
    stevennn09 Member
    Ohio
    hah.
  12. a-integra91
    a-integra91 New Member
    ohio
    do a new cam by crower or something along those lines
    1 person likes this.
  13. stevennn09
    stevennn09 Member
    Ohio
    yeah. gunna start building the parts collection up for this winter.
  14. legand347
    legand347 New Member
    missouri
    b16a in crx
    what kind of mods am i looking at ? will motor mounts line up? will engine harness and and car wiring hook up ? or will i need adaptors? i know i have to change ecu. i have a 89 honda crx si with a d16a6 non vtec help n e one.
  15. stevennn09
    stevennn09 Member
    Ohio
    where the hell did this come from.
    and i dont want a hard vtec hit. i just want like a notice in more power. does anyone understand that
  16. hope801
    hope801 Active Member
    maybe u could push halfway down on the pedal untill u hit VT then floor it. u will definitely see a noticeable gain in power then.
    VT is gay anyway. throw a 13b in there
  17. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    VTEC shouldn't really be felt unless you don't mind being slower.
    Get bolt-ons then tune: detuned regular map; tuned VTEC map along with nitrous relay hooked up to VTEC solenoid. That'll "hit" hard.
  18. stevennn09
    stevennn09 Member
    Ohio
    thanks for all the reply's.
  19. BrutalB83
    Rochester Hills, MI
    Start your own thread jackass...
    Yes, we understand it now that you've explained yourself further. Your initial post was a bit vague and confusing though...
  20. stevennn09
    stevennn09 Member
    Ohio
    my bad. but where did that post come from about the crx? it's so random.
