Vx To Z6 Swap
Discussion in 'HYBRID -> EG-EK / DC' started by ahedau, May 27, 2003.
  1. ahedau
    ahedau Senior Member
    Middle GA
    I just finished my low budget swap and I have two problems:
    1) I have an extra 6-pin connecter from my VX ECM wiring harness that the Z6 engine harness doesn't use. I figured out that 2 of the wires are for the VX's EGR valve. Anyone got a clue? Should I care?
    2) The engine lopes at idle from about 1800-2500 RPM. Someone said it's the ICV leaking. I do not have a vacuum leak and I didn't mess with the IM when I did the swap. Anyone else have any ideas?
    Thanks!
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    click on articles, click on "fixing an erratic idle"
  3. pissedoffsol
    p28 looks for the egr as well.. hook it up
  4. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    :blink: Why would it look for it,when the cars it comes in don't use it?
  5. pissedoffsol
    when we did e's itr swap, we hooked up up to the itr motor cuz the p28 looks for it...
  6. xj0hnx
    C.C.TX.
  7. E_SolSi
    that was the purge sensor or something like that
  8. Car_Tunz
    Car_Tunz Junior Member
    I had close to the same problem in an EX civic. It turned out to be the MAP sensor right on top of the Intake manifold.
  9. xj0hnx
    C.C.TX.
    Same here,my MAP had "come unplugged" (ok I forgot it,fuck off) so for a couple days it idled high and was sluggish in the first few hundred RPMs.I also have the EGR plugs (both of them) just hangin' out in the bay,it idles perfect.
  10. ahedau
    Middle GA
    MAP sensor was the first thing I thought of. I took the old one off my VX (same part#) and that didn't fix it. I'm pretty sure the IAC is malfunctioning. The IAC is not a direct swap between the motors so I'm looking for one now to rule that out.
    Thanks for all the suggestions and to 92b16vx. That link was perfect!!
