wastegate question
Discussion in 'Forced Induction' started by spoolin@idle, Nov 29, 2006.
  1. spoolin@idle
    spoolin@idle D Series FTL
    Kansas City
    Motor: fully built LS non-vtec
    Turbo: T3/T04E 57 trim .63 a/r
    Planning on running around 8 psi and initial tune, getting used to the car. And then on 110 octane running somewhere in the region of 18 psi. I'm wondering which wastegate (external obviously) would best suit my needs. Would the Tial 38mm be large enough or should I move up to say a 44mm?
  2. reikoshea
    Dallas, TX
    you should be fine with a 38mm wastegate. ive seen guys making 600+ hp still using the 38mm
  3. spoolin@idle
    Kansas City
    saweet. thank ya.
    i am picking up my block from the machine shop very soon. she's gonna make a great cupholder for the time being until i get all my bottom end parts in.
  4. pissedoffsol
    it sounds dumb, but more boost = less wastegate needed.
    until of course, you let off :p
  5. spoolin@idle
    Kansas City
    letting off is for quitters lol
  6. silver
    silver Senior Member
    St. Louis
    To expand on this, with the same spring pressure you want a smaller surface to decrease pressure on the wastegate (pressure = force x area).
