Wastegate/Turbo question
Discussion in 'Forced Induction' started by jOnZ, May 13, 2008.
  1. jOnZ
    jOnZ JDM jOn
    How could I run my external wastegate spring by not connecting the vacuum line to the turbo because my turbo dont have the nipple on it for the vacuum.
  2. amadeuscr
    amadeuscr Member
    You can use the intake manifold vacum line but you need a check link on that line cause you can't put vacuum on the actuator , only pressure ! ,
    pd: I am not really sure if that's the line you refer to !
  3. t3t4delsol
    t3t4delsol New Member
    York, Pa
    most turbos atleast have a screw on the compressor housing, take out the screw and buy a nipple at the hardware store that has the same threads
  4. HondaElite
    HondaElite senior member
    fall river.mass
    this is my boys kit..theres no screw on it..they mighta filled it or sumthin....what about the red hose the goes to the t/b from the charcoel can..could he run it from there? and have the bov to the other vacume behind the i/m?
  5. SLOWdelawareEG
    SLOWdelawareEG my cars go fast
    hilton head island, sc
    run it to intake manifold vaccuum source
  6. Turbo&Auto
    Turbo&Auto Nick Go FAST!!
    East Burg, PA!
    T off of the fuel pressure regulator vacuum line or the brake booster. Ive ran vac/boost to a WG without issues. Ive also heard that it shouldnt see vac though like someone mentioned.
