weird knocking noise
Discussion in 'Civic and del Sol - EG and EK' started by delsolproject112, Jun 20, 2010.
  1. delsolproject112
    delsolproject112 New Member
    i have a d16z6 and im getting a knocking noise from my alternator its only when you rev the engine to about 1500-2000 and when driving when the cars idling it doesnt make the sound and if you hold the alternator and pull it stops making the sound. what could be causing this?
  2. 8secHonda
    8secHonda New Member
    my guess is ur alt.bearing maybe going out.
  3. delsolproject112
    anyway to check? thanks for the input
  4. E_SolSi
    take the alternator belt off
    go through that idle and rev range
    see if the problem goes away
    replace the alternator
  5. 78civic
    78civic Junior Member
    NW MS, Y'all
    OR your lower bolt could have loosened and backed out/off. and just the top bolt holding it on..
    Is your batt light on?
    Is it too hot to touch? (the alt that is)
    E
  6. cj_89
    cj_89 New Member
    i have a similar problem,sounds like a weird squeeking on mine.It is constant at idle and is fairly loud.
  7. 8secHonda
    sounds like your bearing has went out in your altenator. usually will have a idle irritating noise like that but quiet down when above idle...
  8. cj_89
    cj_89 New Member
    im driving this months like it and it hasn't give me any trouble yet.Just annoying when your at idle with people walking by.Sound like 2 birds f**king lol
  9. delsolproject112
    my battery light isnt on and it not too hot ill check my bottem bolt
