ok so i swapped everything in. i had a d16y7 in my 97 hatch. i swapped to an 2000 d16y8. well in doing so i had problems with it starting. so i noticed the thermostat housing ground wasnt attached. so i did that and the car starts. well the problem now is that the car idles high and the CEL stays on. now i didnt wire the knock sensor or the vtec, but i doubt thats the problem here. i can give it hardly any pressure on the gas pedal and itll climb, but wont go pass about 2000 rpms. if i give it more than a slight touch it dies. oh and after it climbs to around 1000-2000rpms with me giving it gas, if i let off the pedal the car will die. what could this be from? also i dont know what hoses hook into the intake manifold. there are 2 nipples on the intake manifold, one goes to the pcv valve, and below that there is another...where do i connect to/from?
it will fix your problems grasshopper now before you go negative reppin ppl make sure they dont have the power to put you i the red
good because you will never see green again, that way you cant neg rep anyone else for giving there opinion on fixing a problem
You didnt wire up sensors and your check engine light is on and you are wondering why the car runs like shit?
First off you bash somebody who is trying to help you. Second all of my cars run right so who is the dumbass? I will tell you why your car doesnt run right, its because someone who doesnt know what they are doing is turning wrenches under the hood. That person is too stupid to respect people who know what they are doing to get the advice they need.
wow, you are a dumb ass. you come here looking for help and you are an ass to everyone, you will not get any help that way. rep to AHHVTEC for the neg. rep to 97hatchdx
You know he's probably one of the most helpful people you'll meet. So if you're so fucking high and mighty and don't need anyone's help, go figure it the fuck out yourself asshole.
well on his post about it not starting i was kind enuff to mention the waterneck gound he ignored my advice and then three post later ask if this ground not being hooked up could be the problem he is a moron and deserves no help from anyone by the way take your car to the scrap yard and crush it its probaly rice any ways and know one would want it and you dont deserve to even have a tricyle get a life buy some shoes and enjoy walking as thats all you should be doing
