Well, since this is your first post, wecome to hondaswap.com. Secondly, you don't necessarily have to use 76 point font to get poeple's attention around here, but if you feel otherwise, then by all means use it lol. As for your car, you certainly have a good start. The bad news for that generation of Accord is the SOHC. This means you only have 1 cam instead of 2 in the head (That shiny thing where all of the cables dead-end). You have done all of the standard mods so far (or the previous owner has). You've done everything standard you can to help that engine breathe, but now you are faced with two realities. 1) That automatic is geared too high and far apart for real power 2) that engine is SOHC and isn't even VTEC. Even if you were to do the VTEC head swap, it's still SOHC, and that engine bay isn't big enough for the factory V6. Here is the good news: In Japan, Honda puts DOHC engines in more of their cars, and some Honda Prelude engines from Japan have as much as 220HP stock, compared to the 135 HP your car has stock. These engines are called JDM, meaning Japanese Domestic Market, or that they are sold on the Japanese Domestic Market, rather than the United States Domestic Market. Here's the even better news: These engines are virtually a direct fit, and you can easily swap them. For around $1700, you can buy an engine and transmission that will smoke the hell out of a lot of cars out there. Most people who do this swap, however, start with a manual. So I would recommend you do the same, or start reading all about cars now, particularly clutches and so forth, as you would have to convert your car to manual. I suppose you could get an auto JDM transmission, I've just not heard of anyone doing that so far. Obviously, your car has some sex appeal to teenage ricers who want something kinda quick that makes noise, so you could easily sell it and buy a bone stock accord manual to use for an engine swap. If you want to keep your current car, though, and you want it to be substantially faster, you are going to need a bigger cam or forced induction, meaning turbo or supercharger, turbocharger being the better option for that engine. The Accord is actually a pretty light car, weighing in just around 3,000 pounds, even lighter than the Prelude. Weight is not what you are fighting, it is your engine's ability to breathe in. THe header and exhaust mean it is breathing out as hard as it can. The next step, if you are keeping that engine, is to put a larger bore throttle body on the car.
Maxbore.com throttle body boring service
That is the best guy I've heard of to go through, it's reasonably priced and you can be sure he'll do it right. This will have your engine breathing in a little better. The next step is to check out ECU reflashing. The ECU is the "Engine Control Unit," simply the computer that controls your engine. If you have it reprogrammed, it will give you better performance, because from the factory it is programmed to give you good gas mileage and longer engine life. If you program it to feed more fuel into the engine faster, it will give you better performance and may take a bit of a toll on the enigne, but nothing too substantial, it's a Honda
I hope this answered your question, and by all means, ask any more you might have. Another piece of advice I have for you is to go to Auto Zone or whatever parts store you have there and but the chilton's or hayne's repair manual for your car and get familiar with it. This is the same car that I learned about engines from, and that book had a lot to do with it. It's full of diagrams and technical information that is also broken into simpler terms for those who need that as well. It's around $15 and worth every penny. Good luck with your car, and I hope to hear what you decide and how it goes!
