what is a safe psi to run on jdm d15b?
92civy
i am doing the motor swap next weekend (d15b vtec)
so i am looking to boost
i will be using a t3 turbo 42/48 and i am thinking of running 10 psi, is this safe.
what kind of tune will be needed to run this safe?
i am looking for 180-190 whp
this motor has 130 hp stock.
i am going to talk to xenocron to hook me up with a p28 ecu chipped for 10 psi of boost and all other turbo tune maps or wat ever he does
what else is needed in tuning wise?
i am putting in 440 injectors and i am putting a 255 lph fuel pump but what else?
thanks guys
make sure you hook up your waste gate :rolleyes:
you might wnat to get it street tuned. xenocron can give you a good base map but like his disclamer says this is only to get you to a tunner. i would sugest getting that done.
I agree with 10psi:thumbsup: MAX! Anything more may cause the rods to give! :mad:
For boost maps try uberdata, neptune or crome!
The turbo you're using isnt insanely big, 10 should be fine for everyday use. 14psi at the track with some race gas and a good tune. Basemaps are to get the car to idle, from there its immediate tuning IMO :)
