what is needed to switch from cable to hydro
Discussion in 'HYBRID -> ED-EF / DA' started by fakthepolice, Jun 2, 2005.
  1. fakthepolice
    fakthepolice Senior Member
    what is needed to change from a cable to hydro transmission on my DA teg?
  2. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    A hydro tranny, and Hasport's conversion kit. It's like $300 or so, and includes the tranny mount you'll need along with an adapter to use your cable clutch.
  3. fakthepolice
    what if i change my block and tranny to hydro, because know i have a b18a block/ gsr head and i was wanting to change it to gsr block w/ gsr tranny(hydro) would i still need to get the kit?
  4. ripperbone
    ripperbone angry bear
    Oklahoma
    you still need the kit no mater what block you use. your car came with a cable.
    or you could go to a junkyard and get the petal assy of a newer integra and clutch master cyl. and lines and make your car hydro
  5. fakthepolice
    how much will that run me?
  6. B16CRX
    B16CRX Senior Member
    Greenville, SC
    A lot mroe than teh kit and it will take a lot more work to get it to work.
