What Is This Sensor On The H22?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by ohmstable, May 27, 2003.
  1. ohmstable
    ohmstable Senior Member
    Toronto, Canada
    There's a solenoid of some sort mount just over the fuel injectors. It looks just like the purge control solenoid (with the round cap like thing on it). It has a vacuum hose going to the fuel pressure regulator and it has a connector with 2 wires. Does anyone know what this solenoid is for and what it's called? if possible what color wires should be going to it?
  2. Accordturbo94
    Accordturbo94 Senior Member
    If its on the left hand side its I believe the EGR I could be wrong...
  3. ohmstable
    Toronto, Canada
    No it's not the EGR valve for sure. For now I've got it unplugged but I really need to know what it is
  4. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    I think I know which one you're talking about. I'll go out and look when I leave work, and post it up tomorrow.
  5. PRELUDERR34
    PRELUDERR34 Junior Member
  6. ohmstable
    Toronto, Canada
    what's IAC? what does it do?
  7. mariowc
    mariowc Junior Member
    Littleton, CO
    Idle Air Control. If I am not mistaken, it's a valve that allows more air to pass by the throttle plate to increase idle RPM.
  8. Vexamus
    Vexamus Member
    Negative, if you're talking about the purge valve looking thing right over the fuel rail, that's NOT the IAC, that's on the intake manifold.
    What you're looking at is call the Fuel Injection Air control valve. What it does is between 1500 and 3500 rpm(or so) it allows air to enter the fuel rail, it's completely a waste of time to use it, just ensure that you use Hondata or an AFC to adjust your maps for that range otherwise you'll run rich. It's an emissions control device.
  9. ohmstable
    Toronto, Canada
    Thanks for the info. Currently mine is not connected. I'm going to be chipping the ECU so hopoefully that'll take care of the fuel maps.
  10. haccord141
    haccord141 Senior Member
    So Cali
    ok everyone, i have not read abput his at all, so i would like and answer, not go look over there in that topic. ok my question is: is it good to run rich when u race and should i get rid of the fuel injection air conrol valve. and how would i remap the fuel, i need and answer plz.
    peace
  11. dohcvtec_accord
    The left lane
    I really can't understand what you're saying/asking, but please don't jack the thread. Just start your own.
