what the best swap for auto X
Discussion in 'HYBRID -> EG-EK / DC' started by cxjon, Oct 21, 2002.
  1. cxjon
    cxjon Senior Member
    man+k+toe
    i m not really interested in drag racing but was wondering what swap would work better for auto x for my cx..... better yet what kind of motor set works best for it.... i m interested in a gsr swap but but wondering if thats the best swap/set up for the job
  2. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    NA or small turbo is going to be your best bet. I'd say the GSR is a great swap for AutoX, just be prepared to be owned by the guys that have been running modified cars forever and have more mony to put into their cars than you. (Unless you are one of those guys)
  3. E_SolSi
    the GSR swap will work well for auto X... it has good midrange power for comming out of turns ... the Type R would be good as well because of the closer gearing allowing you to stay in high RPMs .... other than those id say the B20 with a GSR or Type R tranny would be good it has more torque and if you were to throw a B16 head on that and do some work to it ... that would probly be the best setup
  4. E_SolSi
    as far as autoX goes though ... you will see larger gains from high quality suspension and brake upgrades than power upgrades ... that and put some serious thought into attending a drivers Ed for auto X
  5. stpracer
    stpracer Senior Member
    Grove City, Pa.
    this is the ultimate answer to autox - slow cars with a good suspension and a good driver will win every time over hp.
  6. phunky.buddha
    Dallas / Fort Worth, TX
    Plus no engine work will keep you in an easier class, so you'll be able to place higher and win more often. Check your local auto-x rules to see what class you want to be in, then plan your mods accordingly.
  7. cxjon
    cxjon Senior Member
    man+k+toe
    i would have to drive three hours to do it but will find out. i was thinking of going with itr tranny for for better gearing but i was wondering what motor would work best but affordable still
  8. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    if you do an engine swap it boost you up so high, youll be racing much faster cars. I think that in street modifiyed you can have a swap but i am not sure.
    Everyone is right when they say the slow car with a good driver wins. The autoX i went to, this old 80's VW GTI in the stock class was pulling better times than alot of the cammaros and Mustangs. That driver rocked, he three wheeled it on almost every turn.
  9. cxjon
    cxjon Senior Member
    man+k+toe
    yeah but my car is slow as hell! i have a cx..... if i had a dx or a si i would leave it alone but i dont so i m fucked. i m ordering h&r cup kit for suspension with energy suspension urethane bushing and shunk2 front strut bar lower rear tie bar. the drop is 2 inches up and i think 1.75 in the rear... i m not worring about camber cuz i was remembering that a little camber is good 4 auto x i heard once here.
  10. asmallsol
    hey tell me how the urethane bushings are once you get them on, i am planning on doing basicly the same setup but i am going with progressive springs (bit softer) Some one told me that those bushings are a bitch to put on. Anyone here know for sure?
  11. cxjon
    cxjon Senior Member
    man+k+toe
    i m worried about them too.... i can tell yeah i dont want to pay anyone to do it :p
  12. asmallsol
    That is the thing that i am afraid off with my car is the suspention, swap i think i will be able to handle but the suspention seams like it is going to be hard. I want to build my car for autoX too, not straitlining
  13. cxjon
    cxjon Senior Member
    man+k+toe
    i still want to be able to beat someone in a drag tho but i really like driving thru turns and what not.
    where can i find info about auto X in my state... i live in minnesota and heard there is some in st cloud mn but i live in mankato and i never heard about it in my area
  14. asmallsol
    Myautoevents.com they should have stuff about your region
    the only thing is most autoX things are done untill spring
  15. E_SolSi
    go to SCCA.org .... thats your best place to start looking for info on autocross .... its under te heading "solo II"... there may be links to clubs in your area
    also i found this http://www.mnautox.com/openbb/ you should find info there :)
  16. cxjon
    cxjon Senior Member
    man+k+toe
    for auto X whats more important... torque or horse power?
    is it better to have a motor with vtec or with out?
  17. cxjon
    cxjon Senior Member
    man+k+toe
    thanks for the help.... my car should be done well before spring
  18. asmallsol
    i am still kind of a rookie but i am going to have to say tourqe. Tourqe is what helps you pull through the courners. If you are going na then vtec, if turbo than go without.
    When you autoX you bearly ever shift, (basicly 1st then 2nd for most of the race, 3rd if you are a good driver and can get speed and back down to first if your syncros work (mine dont so i just kept it in second.)
  19. E_SolSi
    id say go with VTEC ... it lets you drag the gear out further ( not as much shifting once your up in your power range )...keep yur RPMs high with good shifting and youll be fine... learn heel toe braking and youll hit the corners smoother ( with higher speed )... as far as whats more important, neither really is ... its all about braking for the corner later and making the corners as fast as possible and following "the line" ...
    get the book "Going Faster Mastering the Art of Race Driving" that is probly the best book for learning technique ... and i still say take a drivers Ed
  20. pissedoffsol
    the best swap for autox? none.
    bone stock makes you the most competive.
    IF I were to build an auto X'er... it would be a 91 crx si, bone stock with 14" racing slicks. thats it.
    when you add swaps and mods- it puts you in a class with porsches and shit- so keep that in mind.
