does it say h22a1 on it ?It's definitely JDM. The USDM have changes every year but I'm not sure. I need the pin out for the engine wiring and don't seem to be having any luck.
Well M8 I can tell you that is a 4th Gen Motor. The 91 Lude Si's had B20 in them with DOHC's and in 92 they started to make H22a's all the way threw 96. So its eatehr a 92,93,94,95,96 because in 97 They went to the H23A which is a non vtec anywayz.. thats what my but who works at honda her in Vermont said.. hope it helps some!
Dude, what the hell???
They didn't switch to the H23 in 97. Why would they put a less powerful motor in the newer body style? All 97-01 Preludes have H22s, there was no other motor choice. From 92-96 the Prelude had either an F22 (base model), an H23 (Si model), or an H22 (Si VTEC model).
You've got it completely backwards. The H23 was available from 92-96 and then dropped for the 97-01 generation, not the other way around.
If somebody who works at a Honda dealership told you that then they should be fired; they have no freakin' clue what they're talking about...
Edit: I just noticed your profile says you have a 98 Prelude...how do you not know this???
